In an Extended Edge Switching topology, removes the bridge port extender (BPE) slot assignment applied to an This command is available on all Universal switches supported in this document. identifier on the specified MLAG peer when the port connected to the BPE is physically connected to the MLAG peer switch.
| vpex | Specifies Virtual Port Extender (VPEX). |
| mlag-id | Specifies a unique MLAG identifier of the MLAG port attached to the bridge port extender (BPE). |
| mlag_id | Specifies the MLAG identifier value of the MLAG port attached to the BPE. Range is 1–65,000. |
| slot | Specifies unconfiguring the slot identifier for the attached BPE. |
N/A.
The configure vpex mlag-id mlag_id peer peer_name slot slot_num command allows the MLAG peer that does not have a port in the specified MLAG to declare a Extended Edge Switching slot on that MLAG. This command enables you to unconfigure a previously declared slot on that MLAG.
# unconfigure vpex mlag-id 11 slot
This command was first available in ExtremeXOS 22.7.
This command is available on ExtremeSwitching 5420 and 5520 series switches, and Extreme 7520-48Y switches.
